Eléctrical issues
Hello I saw the Vosk video on youtube about eléctrical installation.
But do I still need a 30 amp outlet and 30 amp breaker switch and 30 amp eléctric wire or cable installation on my house , if I only have 4 dodge miners.? Eléctricians are fighting with me they say that 15 or 20 amps are enougth for the set of 4 miners for they only consume about 200 watts each, can somebody explain to me please Im not buying any more miners until I have some place of my own and that may take a while .
A Mini-DOGE requires 233W of power. See asicminervalue.com or Goldshell’s web site or any other host of sources
P = V x I where P = power in watts), V = volts, and I = current in amps.
Your normal, wall outlet current is 15A (i.e. a 15 amp breaker) at 120V. Let’s assume your voltage is a bit weaker at 108V. So for 4 Mini-DOGEs, 233W x 4 = 932W of power consumption. Since P = V x I, then I = P / V. So 932W / 108V = 8.6A.
So a single, typical US/Canada etc household 15A circuit can run 4 Mini-DOGEs without an issue so long as you’re not drawing more than 6.4A (i.e. 15A circuit breaker - 8.6A Mini-DOGE consumption) from somewhere else on that same circuit. Otherwise, you’ll start popping the breaker.
Hey Thank you very much
