Topic says it all. Which pool do folks recommend for mining ATC on an asic?
Too funny. Silly spell check. You are correct: ETC.
Thanks for the info. Will look into it.
Go have a look at the pool options over here:
https://miningpoolstats.stream/ethereumclassic
The responsible choice is to not pick the top one so things stay properly decentalised (It’s spelt with an S where I live)
I have 3 V1 Mini’s set to 2miners, with f2pool as a backup. It’s been quite surprising to see how often one of them is on f2pool.
