Ethereum Mining Rig
Newbie question, and thanks in advance.
I’ve been offered a full mining rig for £2500. Is this a good deal please;
12 x SAPPHIRE AMD RX 580 NITRO+ 4GB OVERCLOCK GPUs
BIOSTAR. TB250 - BTC PRO motherboard with an
INTEL PENTIUM G4400 LGA1151. 3.3 GHZ CACHE. 3MB and
BALLISTEX 8GB DDR4 - 2400 UDIMM. 1.2V RAM
A BIOSTAR S100 SSD running EthOS, LINUX and CLAYMORE
2 x FAST HAPPY 1800W MAX OUTPUT PSUs
12 x GPU RISERS
10 x DC BRUSHLESS FANS
ALUMINIUM FRAME
That seems a bit steep for 4gb cards since you’re limited on what you can mine with it.
Ditto on the 4GB GPU’s, it definitely limits your mining ability!
