Ethernet splitter?
:thinking: Is there any special type of ethernet splitter I should be running? I see they have several different ones ranging 10/100/10G ??? I didn’t see this topic in the search bar so I posted about it…
Wouldn’t you only need one of these splitters/switches if you were running low on ethernet ports? If so I’d go with the cheapest TP-Link one available, don’t see how you’d need a “special type”.
Sounds good to me,thank you so much for your help.
