Ethernet VS Wifi in Helium mining
Hey there, I just wanted to know if Ethernet or WIFI is better for helium mining, and what factors are involved, I know for one that syncing takes longer on WIFI, but does this affect the earnings? Thanks
They say there’s no difference as long as you have a good internet connection but my hotspot kept getting relayed while on wifi, and my I have a strong wifi signal with 600mbps download speed. Ethernet is a safe way to go but if you have no choice just make sure your signal is high
@AdamSiali
If possible its always best to have something hard wired to the network.
Yes WIFI if fast these days, but there is still a slight delay with WIFI.
Thanks for the reply guys, Can i just ask, how do i make sure my signal is high?
the main thing is distance, using the right channel, but walls, other electronics etc can also affect signal
