Hey Crypto Fam,
I hope you are doing well out there, being safe in this crazy world! The video card I was able to test with my buddy Nemisist was the EVGA Geforce RTX 3090 XC3 24 GB GDDR6X. If you have any data on Algos, Miners, or have command-line arguments - parameters that you believe should be used please share with the community below. I will have a possible video recap of our live testing, so check back on this thread for updates. Links to the live stream below. Thanks and take care.
A few key things, mark sure to check any notes under each section for some things we noticed during mining. We were unable to test every single Miner and Algo, but right now the current version of Gminer did not work when mining KawPow - Ravencoin so we had to use T-Rex miner.
Keep in mind these Mining Devs are having a hard time getting the new GPU’s like we are, and it will take time for them to optimize kernels. Not to mention Nvidia putting out Driver revisions so hang tight.
Live testing of the EVGA RTX 3090 Mining Performance https://youtu.be/9TsD2kAcKaA
Phoenix Miner - Ethash
| 119 Mhs | 0 core / 1000 mem | TDP - 104% | 346 Watts |
| 106.2 Mhs | 0 core / 0 mem | TDP - 100% | 290 Watts |
| 71.58 Mhs | 0 core / 0 mem | TDP - 80% | 284.8 Watts |
| 101.2 Mhs | 0 core / 1000 mem | TDP - 80% | 279.5 Watts |
| 106.2 Mhs | 0 core / 1125 mem | TDP - 65% | 226.6 Watts |
Note - ETH pill showed no positive gains, and only introduce instability in the system
T-Rex Miner - KawPOW - RVN
| 52 Mhs | 0 core / 0 mem | TDP - 104% | 365 Watts |
| 44 Mhs | 0 core / 0 mem | TDP - 100% | 302 Watts |
| 45 Mhs | 100 core / 0 mem | TDP - 100% | 302 Watts |
| 45 Mhs | 100 core / 500 mem | TDP - 100% | 302 Watts |
| 40 Mhs | 100 core / 0 mem | TDP - 80% | 279 Watts |
GMiner - BeamHashIII
| 54.8 Mhs | 0 core / 0 mem | TDP - 100% | 312.6 Watts |
| 54.6 Mhs | 125 core / 0 mem | TDP - 100% | 312.6 Watts |
| 53.5 Mhs | 100 core / 500 mem | TDP - 100% | 312.6 Watts |
| 53.5 Mhs | 100 core / 0 mem | TDP - 80% | 279 Watts |
| 52.5 Mhs | 125 core / 0 mem | TDP - 80% | 279 Watts |
Note - Not much performance gain, Miner Kernels need optimizations and seems the software (i.e. MSI Afterburner) adjustments are not doing as much as we would like. Try Nvidia Inspector and see if it works, otherwise during testing, if drivers crash go ahead and restart the system.
GMiner - Equihash 201,9 - Aion
| 556 Mhs | 0 core / 0 mem | TDP - 100% | 307.8 Watts |
| 568 Mhs | 125 core / 0 mem | TDP - 100% | 307.8 Watts |
| 565 Mhs | 100 core / 500 mem | TDP - 100% | 307.8 Watts |
| 537 Mhs | 125 core / 0 mem | TDP - 80% | 279 Watts |
GMiner - Cuckatoo32 - Grin32
| 1.12 G/s | 0 core / 0 mem | TDP - 100% | 324.7 Watts |
| 0.95 G/s | 0 core / 0 mem | TDP - 75% | 263.4 Watts |
| 0.97 G/s | 125 core / 0 mem | TDP - 75% | 263.4 Watts |
| 0.97 G/s | 125 core / 500 mem | TDP - 75% | 263.4 Watts |
T-Rex Miner - MTP - Zcoin
| 7.09 Mhs | 0 core / 0 mem | TDP - 100% | 321 Watts |
| 7.27 Mhs | 100 core / 0 mem | TDP - 100% | 321 Watts |
| 7.1 Mhs | 100 core / 500 mem | TDP - 100% | 321 Watts |
| 7.29 Mhs | 125 core / 0 mem | TDP - 100% | 321 Watts |
| 5.9 Mhs | 125 core / 0 mem | TDP - 80% | 279 Watts |
| 6.1 Mhs | 150 core / 0 mem | TDP - 80% | 279 Watts |
