Fan shrouds for cooling
Does anyone here use fan shrouds on their sj19 miner? I live in west Texas and the days are already up to 90. I’m looking for a quick and easy way to get some quiet and cool off my miner. My miner is in my garage so I raise my garage door a little to vent but not sure if that will do it when the temps reach 110. Any help would be appreciated.
Personally I designed and printed 3D Printed ducting that attaches to the miner fans and enables you to connect a 5/6/7/8" ducting to the miner, Then you have a vent in your window. This way the heat is blown out the window away from your miner. The cooler you can keep the room the Safer it is, but it’s also beneficial to the equipment as well.
My eBay store
Email [email protected]
I’m based in central Texas so do understand high temp concerns
