For some reason my fans are spinning opposite each other. They are both blowing into the machine. Has anybody had that before? Fix?
Unplug your l3, take one off and turn it around. It’s super simple, then just power the unit back on. Make sure to flip the correct one though. I’ve heard that reversing the direction of air flow through the miner shows cooler Temps, but that is just because the temp sensor is closer to the incoming air after the fan is flipped.
I did just that. Do you know why this happens?
BeCAUSE SOMEONE IS AN IDIOT> lol … it happens… unless someone was trying to get u to fry ur asic
def bad on the l3. will burn that up quiker then u can say… i had gotten one not toolong ago i sent to someone… told me the exact same thing
