Firmware Update For L7 Available On Bitmain
Been using it about a week and I am getting significantly better performance. Less hardware errors and better hashrate (about 100 MH/s).
Awesome!! Thanks for the update. I’m getting killed with Hardware errors!!
Hi Robert, I’ve been moaning with my L7 fine and would like to update the firmware but the Bitmain site only shows firmware download for the R3 when you click on the ltc/doge script dropdown menu. I have found firmware on other sites but am definitely not going to download and flash the unit with these. Any idea if there is still current genuine Bitmain firmware for the l7?
Regards Stu
Thats weird . I just did the search for it through my phone… it comes up on the mobile website but when I search or it through the desktop you’re right and there’s only one option
https://file12.bitmain.com/shop-product-s3/firmware/f96395ad-42b1-40a9-a1ed-4a80ca0503fe/2022/02/16/11/ANTMINER-L7-release-202201241601.bmu
Either way this is the link to the L7
Many thanks, I shall check it out. I want the bad boy earning its full potential ha ha ha
DM me and I can email it to you if you’d like!!:v:t3:
