First timer into btc mining. Looking at 10 units of bitmain s19k pro (living in malaysia with cheaper electricity)
Currently living in Malaysia and want to get feet wet with btc mining, looking to purchase 10 units of s19k pro, is that the best option currently in the market? Anything that I need to be wary about getting into this?
I’d look into your local tax laws and make sure you know what you’re doing with that side of it, like where I live I only get taxed on buying and selling, and if I receive it without buying I don’t get taxed, but every country is different. I’d also take a good look through the forum to find sellers with a good reputation. Personally I recommend Apexto and Zeus and with your location shipping shouldn’t be too bad from them. Good luck
In my opinion…
Your ROI is the first thing to consider…Second, takes a lot of power to run these especially 10…(based on the model S19) 10 will be about 150 amps running 24 hours a day. Make sure your current power source can handle it. Third, they are very loud and produce a ton of heat, make sure you have adequate ventilation and air flow.
