2 heat sinks came off one of my hashing boards. The board no longer works. If I solder them back on will the board work?
Also, does anyone know where you can buy more boards for the S9K?
Thanks.
Thanks.
if it coming off means you overheat your asic and chips are dead
you need to buy repair tool and new chip testing board or another chips is not fail
