I am running flexfarmer on an old Raspberry Pi - plotting my own plots so its taken a while to get going. Saw today that Flexpool and flexfarmer will be shutdown as from November 1st.
I preferred flexfarmer as running of the node and the space required for that was just becoming painful to manage as it seemed to take so long to synchronize (like a week +)
Is anyone aware of any similar products that they have had experiences with that does the same as flexfarmer?
So for those using the now closing Flexpool.io with Flexfarmer,
Spacefarmers.io is probably the best alternative. I switched to it and it’s been great thus far. I kinda like it better than Flexpool.io….
They offer a community node which does the same thing that Flexfarmer did, but works with Chia Client or Madmax Gigahorse Client. You can farm without running a full node regardless on what type of compressed plots you are using.
Here is a good article that explains how to switch to their pool from flexpool. It covers pretty much every farming situation.
Wanted to share as the closing of Flexpool.io came as a surprise, and I wanted to find another pool that I could farm without running a full node and still farm with Gigahorse plots.
Does anyone have a walk through for moving the evergreen miners over to new pool? I’m using flexpool.Io still and it looks like Nov 1 is shut down day for them. Thanks!
Evergreen will most likely take care of this for all Evergreen owners, via automatic updates. I believe they are beta testing the switch to another pool currently…
