How’s it going everyone. I’ve seen a constant question come up on how to earn DHX while mining MXC with the m2 Pro miner, so I went ahead and created a flow chart. The basic idea is you have a starting amount of MXC and DHX. You lock the MXC, and bond the DHX to a ratio of 5k-10k MXC per 1 DHX (depends if you have a miner or not & lock time). If your locked MXC gives you enough mPower to “fuel” your bonded DHX, you’ll maximize your DHX earnings potential. Hopefully the flow chart image helps you visualize this process.
If anyone has any questions let me know.
