MINI-DOGE PRO
CK-BOX
HS-BOX
LB-BOX
SC-BOX
HS-LITE
CK-LITE
LT-LITE
LB-LITE
KD-LITE
KD-BOX PRO
KD6SE
KD-MAX
HS5
HS6
Which one do you want to know(ps:Can you contact my WhatsApp? I’m off work haha,I can only reply to you on the phone)
@Nallexy It depends. What’s the utlimate hashrate of that GPU rig? I’m not a GPU miner so the specs that you provided really don’t tell me anything. I’d get the hashrate and power consumption (just because it has a 1000W power supply doesn’t mean that it’ll consume 1000W) and input numbers here:
Then compare $/day after electricity cost and pool fee to cost of the rig. That should give you days to breakeven and perhaps at least an answer.
Interestingly, FLUX difficulty has been trending downwards for the past several months - opposite of most PoW cryptos. I’m unclear what this signals but it might be worth looking into it. I do know one can create a FLUX node and stake FLUX. So it might be moving from PoW to PoS, but this is purely uneducated speculation on my part. Hopefully someone who has better knowledge of FLUX will chime in.
You also could mine KDA and swap to FLUX if you want FLUX exposure. The two coins tend to move together directionally, though they’re clearly not perfectly correlated.
