Hey anyone remember Vosk mentioning that he was able to modify his C2 to fit 3 miners instead of 2? I might be mistaken but I swear I remember him saying that. Anyone else do anything like this. If so i would super appreciate an insights into how you did this!?
I finally have a connection to overclock software for my KA3’s and really wanna test it out. They need to be submerged before I can kick em up on hash though!
i doubt he said that. plus i cant imagine it would fit even 3 stripped down asics, unless you really broke them down.
Yeah I had someone else told me there was no way that 3 would fit in there but I swear I remember him saying you could take a bracket out and fit three. Idk maybe I dreamt it! lol
I swear there was a video he said you could fit more of a specific design, maybe whatsminers? I’ll do some digging
Appreciate it bro. Im pretty sure he was talking about his ka3 submersions which is exactly what i am trying to do.
Just looking at the specs 398(L)*298(W)*392(H)mm I’m assuming that’s the max size you can fit inside the tank.
Looking at specs of KA3 is 430mm X 195.5mm X 290mm
Once you take the fans off, it should take off 76mm, the fans should be 38mm each, so height should fit assuming the specs provided is what you can fit in the tank, but there would be no way you could fit 3 KA3 miners in that tank, I do t think you could fit more whatsminers either
The C6 tank is 912(L)*404(W)*355(H)mm, which can fit 6 antminers, not sure about KA3 as that would be 354mm without fans, the whatsminers are 430mm x 155mm x 226m, so you’d be able to fit 8 assuming the 1mm gap at the top is enough. I think I remember the video and he said you might be able to fit more whatsminers
Thanks for all that research Shred! I appreciate you buddy! So I mean technically because you were saying that the KA3 would be 354mm without fans that should be referring to with length right? so technically they should fit because the 355 dimension of the C6 that you cited is the height dimesion?
Yeah but I think you’d have to double check with fog hash to see if it’s enough and can fit those models
