Hey crypto fam. I am sure I am not the only one but my garage is super hot from mining. I don’t have a window but I will be installing a security door to have some air flow. I was thinking of getting an industrial shop fan or a portable A/C unit. The unit has a reservoir to add water. Is this safe or ideal?
I’m sure someone else with more knowledge will chime in but I read somewhere that AC’s aren’t. Would you use a shop fan to remove hot air or bring fresh air in? What temps are your boards running at?
I had excess heat issues in the basement room that I use for mining when I first setup my miners. I ended up purchasing a 24" shop fan off of ebay that I put in my wall and it’s helped tremendously. As long as you’ve got a way to bring fresh air in, it pushes over 4200 cfm and with a 2400 square foot house I haven’t needed to turn my AC on once this summer up here in Michigan. It only cost me ~$300 and it has variable speeds.
What’s your set up look like? I use 8-12” exhaust shutter fans and also run a 24k mini split for times when I cut 50% of my exhaust fans off and run the mini split to help cool the garage down usually gets around 105-115 inside with mini split it’ll go down to 75-80 degrees on 95+ degree outside weather
youll need to find a way to exhaust the hot air out otherwise itll stay hot in there
if you dont wanna cut a hole in the wall next option could be cut hole in the garage door or just leave the door open to get the heat exhaust out, just sharing personal experience
If you are not going to cut a hole in your wall, then you must install your door in the most ventilated location. And the dust-proof setting is carried out to prevent the backflow of air. Then dust your miner regularly to prevent the miner from running too hot. The best way is to take a water cooling system to cool down.
ventilation is key! Don’t need a big fan, just a duct fan will work well, but it needs to be pulling the air from the miners and getting it outside. Running AC to cool your miners won’t work, you’ll spend more on electricity to manage that heat load than you’ll make back no matter the miner but especially on the big ones. you’ll fine a huge difference as soon as you get that hot exhaust air duct-ed out.
A/C may help but only if your garage is well insulated.
Moving hot air out is the key. Here’s my setup (I’m in Florida)… I figured, it’s better to exhaust the hot air through the attic vs. cutting a hole in the wall
You are all correct. I need to take the hot air out with exhaust leading to the outside. When you set it up what is pulling the hot air out? I see the duct work but is there a device that sucks the air out?
Two devices actually:
" TerraBloom ECMF-200, Quiet 8" Inline Duct Fan with 0-100% Variable Speed Controller, Air Tight Metal Casing, Energy Efficient EC Motor. Heating, Ventilation and Exhaust Blower For Large Spaces"
and
" VIVOSUN 6 Inch 390 CFM Inline Duct Fan with Variable Speed Controller HVAC Blower for Ventilation"
Update: I set up a grow tent in my garage. I have the exhaust going out my side door in my garage. What a difference with the heat. I had mixed results. For my set up it was a fail as my KD6 SE and KD Max had the temp at 125 yikes. For exhaust I have AC Infinity T8 and two T6 for intake. When I turned off my KD Max my KD 6 was at 101 and dropping.
My garage was much cooler at least. @creator2000 Your set up looks good. I need to rearrange my miners. I like how you point your exhaust of the miners towards your exhaust fan. This weekend I will rearrange my set up to see if it improves. Pics coming of my current set up.
Update: Well I removed everything and only had my KD Max and repositioned my miner so that the exhaust is being sent out immediately. I also moved my intake as well. With the tent closed it was between 90-95. This was my best yet!
I then added my KD6 SE and again readjusted the exhaust but to my T6 (smaller). There is little fresh air going to this miner. I have a box fan on the outside of tent through vent. I was at around 100-108. I think I might need a intake to the KD 6 SE.
Any recommendations for an exhaust shroud that is good quality?
