Hi. not sure where to begin with powering my Goldshell LT5. it is of course European 220. built in power supply. 50/60 hz. 16.5 amp. I have 220 in my shop (US). do I need to get an up converter / down converter? just don’t want to mess up. I have 2 LT5s. Any advice would be appreciated. Thanks
If you will check out Vosck’s channel, he has a video about electrical needs. I think your best rout would get a 220 power distribution bar (PD bar) and plug your ASICS into it. You may have to buy the appropriate cord to go from the PD Barr to the miner but that should fix your issue. You can get a chart online that shows the different male and female ends and the nomenclature so you can make sure you get the proper cord.
Thank you! I will check out the power distribution bar.
