With the KD using just 205 watts, is it able to be plugged into a traditional wall outlet in
Also what type of power cord should I get?
Which power supply are you planning to use?
Since it’s only 205 watts my 20 Amp fuse for the spare room will be plenty and still be under the 80% rule. I notice it’s not like the power cord like a computer but instead has 6 pins. So was wondering what type of power cord it’d have to get to attach to the kd and then be able to plug I to a standard
wall outlet.
