Goldshell KD6 SE & KD Max - Power
Hey there. First time posting. I have done some research on powering Crypto rigs. I want to confirm before I purchase. I need to know what preparations I need to do before my I place my order.
What is the correct power cord to use? Is it a C19 to C20? Also, do I need a PSU? What kind of 240v plug do I need? Based on research it sounds like a L6-30p. Does this sounds correct?
Appreciate any help and thanks.
David
KD 6 Se and KD Max do not need to buy another power supply
Safest to run it off a pdu on its own dedicated 32amp circuit/breaker assuming your newly bought pdu is rated at 32a.
Vosk has a great go to vid which breaks down the “safest “ way to run these power hungry devices.
https://youtu.be/eZi_yx_koXc
