Not sure what to tell you, verify you’re entering correct info, if that doesn’t work you may need to factory reset box. If you search on here you can find other posts with info on that
Thank you Chris done factory reset its unlocked now which pool is the best one to use with this miner
Hi Chris
Hope all are well Chris just want to Thank you for yesterday for all the help you provided.Got both the Mini Doge working now hashing away really appreciate your help and time. Have A Happy Mining NEW YEAR Thank You.
Hi Joe
Hope all are well Joe Thank you for the support provided yesterday really appreciate for your help.
Wish everyone on this forum A Happy Mining New Year Thank you.
