Goldshell Mini/Box - Not Connecting to Pool
Anyone see this issue before? Instead of showing the normal hashing graphs, I’m getting error message that miner is unable to connect to the pool. I updated the firmwares. So thats not the issue. I have other mini boxes running just fine and connecting to pools.
Is it any of the pools in China? There has been issues. I have new ones that can’t connect but my old ones are running just fine.
I am using F2Pool
Yeah, would be dxpool. My f2pool miners are working.
Yeah they are one of the ones with problems . They had to switch to dxpool.net.
Did you try that yet?
That did the trick. Thanks so much! Appreciate the help!
