Goldshell sc box issues
So in the last several months I’ve picked up 4 of the SC boxes… I also see that they’re now basically giving them away free with orders and pushing a new larger ASIC ……
I currently have 15 goldshell box miners, all running, and have zero issues with any of them, some of them over 1 1/2 years old.
The SC boxes I have,… 4 of them…. All have a connection issue. I am able to see the IP on my network…. But cannot connect to it over the network. The first one I got it working by using the WIFI and connecting directly to it,… plugged the pool info into it and was able to get it mining, so I said screw it, and left it like that,… a month later, another one showed up, latest firmware,… same issue…. Direct connect to wifi, set it up, and then I was able to connect it to Ethernet and it mines just fine…… BUT, I have no way to log into it unless I unplug the Ethernet and connect directly to it via wifi.
What gives? Anyone have these problems before? I literally have like every box miner goldshell makes except the LB box, and the SC boxes are the ONLY ones with this issue.
