I have an 8 card miner on its way…can you run a 3060, 3080, 3090 at the same time on the same motherboard or should they all be the same.
Can’t help but try Google. But I think so as I have a gaming rig with two different GPUs.
its all about getting the drivers to work together. So yes, if you work at it enough, you can get like 3060 and 3080 to work in pairs on the same MB
yes you can run them on the same board
however in some instances the fine tuning for different cards can get challenging, but its possible
I have a rig with Nvidiia and AMD GPU’s running. May take some time, but you’ll get there.
