I’m asking after a friend, he has a gaming pc that uses GTX 1660 for mining, but the point I am trying to get that is he is using MSI Afterburner but doesn’t know which settings to have.
I personally wouldn’t know because I have RTX cards 3060ti, 3070 and 3090.
Can anybody suggest best settings for GTX 1660 on the MSI Afterburner please?
Power Level: 62 or whatever makes the 1660 draw just over 70 watts
Temp Limit: 85 you won’t reach this because you will control power (above) Don’t want limiting.
Core Clock: -502 to -300
Mem Clock: 850 to 1000 This will be up to where the computer crashes and back off a bit.
Fan: 60-80% in manual Adjust fan curve in settings/fan with highes dot Speed 90 Temp 65
Next dot Speed 80 Temp 60 …Next Dot Speed 70 Temp 50 Left Most Dot Speed 60 Temp 45
Then run Autp . Save settings 1-5 and leave Lock open, Start with Windows in Settings.
Quick noob question - is this card still powerful enough / popular for mining? I came across a bargain deal for $750 (a whole gaming PC that included 1660 Super)? Would that be a good investment?
Thank you Dollyshunk - sounds like a nice setup! With the original price tag of $240 - $350 per card building a 12-card rig like that would have been doable, but prices are still more than double that right now, so I guess my big dilemma is it still worth buying the whole new system (gaming pc) that has 1660 Super in it for $750?
I have been using GTX 1660 Ti cards in my rigs. These were purchased in late summer / early fall of 2020 at MSRP of $300 (ish - Tax and shipping). As far as setup I found that a MEM OC of +850 is a not too shabby Ethereum mining card:
Stock 1660 Ti on ETH is about 25 MH/s…
Applying MEM +850 OC, ETH is about 30 MH/s.
As far as the gaming PC with a 1660 Super you are considering, I would look at the other components of the system, and see if they can be used down the road for building a GPU miner.
-CPU
-Power Supply
-Memory
-Storage
-number of PCIE channels.
If it looks like the gaming PC parts will work for a future miner build, then go ahead.
Right sometimes that catches my eye I hate when they do that. The best I see now is $576 they been coming down I paid $611 back 3 weeks. I hated to pay that but I had a computer with no card to play around with to learn. I got months before my Bobcat gets here.
