Per their GitHub, it’s double the hashrate and half the power consumption
Exactly what Joey said!!
Finally, I got my Hs-Box mining Sia now, should I call it Sc-Box now? Great Tip. 2x the hash and 1/2 of the watts. I can’t imagine why Goldshell doesn’t promote this feature. Buy another Hs-Box on eBay fast, before the word gets out!
Awesome !!
Can somebody posts screenshots to verify this?
What hashrate/wattage are you getting mining SIA?
Awesome work, gentlemen.
i ordered mine yesterday so around 09/10 i should be able to screenshot results and do maths
Have been running HS5 mining Siacoin for a few days now using Luxor. So far so good:
Was an easy setup in Goldshell dashboard.
What is the Sia profitability now for the HS Box?
Since this thread is almost two months old, what is the Sia profitability for the HS Box now?
Not sure about HS-BOX setup and profitability for Siacoin - data I posted is from my HS5. Mining SC vs. HS doubles the hashrate and using 30% less power. Maybe you could apply same “formula” to figure out what HS-BOX can do.
Thank you for the screenshot! Awesome
Right now it’s about $85-$95 a month before electricity.
Or 4500 coins a month!! If you want to do some long term predictions. If Sia were to hit .10 in a few years that’s $450 a month if you hold. Not bad for an $800 unit!!
About how many HS coins does the HS-Box miner produce every day?
About how many SIA coins does the HS-Box miner produce every day? @Robert_Connolly said 4500 a while ago - is that still accurate?
mine does (hs-box) 130-150 coins a day in SIA coins.
i usually mine the most profitable and it’s been sia for a while now…
mine did 132 sia coins yesterday. somedays 150…
I’m thinking HNS slightly better as of a few weeks ago?
could be that my calculations are incorrect, but if not, for me the siacoin is still more effective.
