So I keep seeing Nimiq show up on what to mine back and forth with Ravencoin. Has anyone tried mining Nimiq with any luck or profitability? It appears it is profitable with GPU mining when I tried downloading their software it seems like it wants to CPU mine instead. … Any suggestions or ideas on mining this or should I just stick with RVN?
I mined NIM it isn’t worth it for me anyway it uses a similar algo to BEAM and to get the same performance on NIM you have to keep your GPU at max power when I am mining on Ravencoin I can use %50 of the power and get the same performance. Your revenue will be about the same but your power consumption will be way up.
