Helium antenna upgrade question
I read something about a helium antenna update saying that the strongest dbi strength would be able to use was a 9 dbi. Is that a thing? I live 60± miles from the closest herd of miners. Would that be a thing to consider when buying an antenna? I was looking at a 12 dbi
If you’re 60mi away u gotta. Get. High. Also directional antennas are nice for aiming towards a town and are much stronger. I will stop as I don’t know much more. Out of my 5 miners I’ve only made .15 HNT last 24hrs. I’ve heard a lot about the network and potential light hotspot rollbacks!
I was thinking about an omnidirectional 12 dbi and roughly 30’of the ground. Hopefully it would reach two cities within that range.
