if i connect 2 helium hotspot miner in the same room ,same wifi ,same wallet ,will it work???
will passive income gets double for 2 hotspot miner ???
300 to 500 meters
You ‘could’ but for best results you should try and provide a minimum distance of 300 to 500 meters between Hotspots though this could vary depending on the environment (in a dense city closer, and in a more rural environment farther)
and maximum distance ?
Believe it’s around 5 miles of you don’t live in a city
If you watched Vosk’s video on this he said when he had two in the same house it halved the earnings of each miner.
