Just got a Goldshell mini HS box and could use a lil help with getting into it. I scanned and it didn’t show up as “Goldshell”. It showed up in awesome miner and find my goldshell it worked to. The problem is when I put the ip in the search engine It says refused to connect. It says “This site can’t be reached192.168.1.225 refused to connect”.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Been working on it for hours. Help would be very appreciated.
If it has wifi, connect to its wifi hotspot and go to your browser and go to 198.162.1.0. This should let you get to to the dashboard, just make sure you’re on it’s hotspot. Again, make sure you’re on the miner hotspot network and not your internet modem/router. You can access this from your phone or tablet as well @pnipper
