After getting one of my brand new KA3 miners repaired by Bitmain (due to a damaged hash board) I am facing a new problem, with all three of my miners. I run them for several hours and everything looks good, then suddenly hash rate drops down to 0 and stays at 0 until I manually reset them. Then they work again for a bit. But I canβt get them to run for more than one day without this happening again. Sometimes it happens within a few minutes, and sometimes it runs for several hours, but no longer than that. And they donβt always drop at the same time, they seem to drop at completely random times.
I have been going back and forth with Bitmain and they havenβt been very helpful to be honest. First they told me it was a network problem. I investigated everything I could related to my network connection: the mining pool, my router/modem, my firewall, my Ethernet cable connections. Then after spending so much time on that, I followed up with them again and, after re-checking the kernel logs, they are now saying my voltage is unstable. I have metered PDUs and the voltage on all miners is fine, it stays at 240V. I tried to investigate what else this kernel log error could be caused by:
time=β2023-05-28 20:18:24β level=warn pid=886 msg=β>> chain avg vol drop from 1560 to 1.90, pls check <<β
time=β2023-05-28 20:18:38β level=warn pid=886 msg=β>> chain avg vol drop from 1560 to 1.90, pls check <<β
time=β2023-05-28 20:18:51β level=warn pid=886 msg=β>> chain avg vol drop from 1560 to 1.90, pls check <<β
time=β2023-05-28 20:19:05β level=warn pid=886 msg=β>> chain avg vol drop from 1580 to 1.90, pls check <<β
time=β2023-05-28 20:19:07β level=error pid=886 msg=β>> feedback voltage: too many times error, pls check <<β
I think some people online are saying itβs a temperature problem, however the Antminer dashboard doesnβt seem to show abnormal temperature status when I check up on it.
Iβm not sure what else to try, I feel like Iβve tried everything. Does anyone know why this could be happening and what I could try to fix this?
For reference, hereβs a snippet of the kernel logs when the miner hash rates drop down to 0:
===========================================Miner log===========================================
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βopt_algo 2, kda_2110β
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βMiner compile time: Fri Dec 23 18:42:27 CST 2022 type: Antminer KA3β
time=β1970-01-01 00:00:10β level=notice pid=886 msg=platform_topol_init
time=β1970-01-01 00:00:10β level=notice pid=886 msg=check_machine_info
time=β1970-01-01 00:00:10β level=notice pid=886 msg=platform_init
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βchain_offset 0, chain 0β
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βchain_offset 1, chain 1β
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βchain_offset 2, chain 2β
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βreset fpgaβ
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βStart api functionβ
time=β1970-01-01 00:00:10β level=notice pid=886 msg=βBegain check_fan_valiadβ
time=β2023-05-28 16:49:07β level=notice pid=886 msg=βcheck_fan_speed ok, fan_num = 4β
time=β2023-05-28 16:49:16β level=notice pid=886 msg=βeeprom add device: 0β
time=β2023-05-28 16:49:16β level=notice pid=886 msg=βeeprom add device: 1β
time=β2023-05-28 16:49:16β level=notice pid=886 msg=βeeprom add device: 2β
time=β2023-05-28 16:49:22β level=notice pid=886 msg=βminer sn: JYZZECUBBABAC00W7β
time=β2023-05-28 16:49:22β level=notice pid=886 msg=βall backend runtimes have been poweroff.β
time=β2023-05-28 16:49:29β level=notice pid=886 msg=βInitializing the power, please wait, this may take up 1 minuteβ¦β
time=β2023-05-28 16:50:38β level=notice pid=886 msg=βbitmain power fw version: 0019β
time=β2023-05-28 16:50:46β level=notice pid=886 msg=start_heartbeat_thread
time=β2023-05-28 16:50:48β level=notice pid=886 msg=βenable power watchdog: 0x0001β
time=β2023-05-28 16:50:53β level=notice pid=886 chain=0 msg=βChipSetting_get_addr_KDA_2110 detect 92 chipsβ
time=β2023-05-28 16:50:59β level=notice pid=886 chain=1 msg=βChipSetting_get_addr_KDA_2110 detect 92 chipsβ
time=β2023-05-28 16:51:06β level=notice pid=886 chain=2 msg=βChipSetting_get_addr_KDA_2110 detect 92 chipsβ
time=β2023-05-28 16:51:08β level=notice pid=886 msg=βcheck bringup temperature 29 Cβ
time=β2023-05-28 16:51:08β level=notice pid=886 msg=βInitializing chip cluster, please wait, this may take up to 2 minutesβ¦β
time=β2023-05-28 16:52:08β level=notice pid=886 msg=βset freq to 640.00, current voltage 1700β
time=β2023-05-28 16:52:23β level=notice pid=886 msg=βset_miner_start_time total_tv_start_sys=230 total_tv_end_sys=231β
time=β2023-05-28 16:52:28β level=notice pid=886 msg=start_voltage_monitor
time=β2023-05-28 16:52:28β level=notice pid=886 msg=βstart the http thread.β
time=β2023-05-28 16:52:28β level=notice pid=886 msg=βhttpListenThread start ret=0β
time=β2023-05-28 16:52:28β level=notice pid=886 msg=βstart listen on 6060 β¦β
time=β2023-05-28 17:01:48β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 17:15:47β level=warn pid=886 poolno=0 msg=βreject reason: job committedβ
time=β2023-05-28 18:24:42β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 18:24:48β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 18:43:24β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 19:52:00β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 19:53:17β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 20:07:26β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 20:12:01β level=warn pid=886 poolno=0 msg=βreject reason: job not foundβ
time=β2023-05-28 20:20:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:20:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:20:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:22:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:22:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:22:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:22:39β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate last_30min: 47610.656195β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate lifetime: 54826.859758β
time=β2023-05-28 20:22:39β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate last_30min: 47437.762789β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate lifetime: 54685.784343β
time=β2023-05-28 20:22:39β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate last_30min: 47714.465219β
time=β2023-05-28 20:22:39β level=warn pid=886 msg=βno ratio hashrate lifetime: 54752.431833β
time=β2023-05-28 20:22:40β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate last_30min: 47610.656195β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate lifetime: 54826.859758β
time=β2023-05-28 20:22:40β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate last_30min: 47437.762789β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate lifetime: 54685.784343β
time=β2023-05-28 20:22:40β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate last_30min: 47714.465219β
time=β2023-05-28 20:22:40β level=warn pid=886 msg=βno ratio hashrate lifetime: 54752.431833β
time=β2023-05-28 20:22:41β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate last_30min: 47610.656195β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate lifetime: 54826.859758β
time=β2023-05-28 20:22:41β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate last_30min: 47437.762789β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate lifetime: 54685.784343β
time=β2023-05-28 20:22:41β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate last_30min: 47714.465219β
time=β2023-05-28 20:22:41β level=warn pid=886 msg=βno ratio hashrate lifetime: 54752.431833β
time=β2023-05-28 20:22:42β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate last_30min: 47610.656195β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate lifetime: 54826.859758β
time=β2023-05-28 20:22:42β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate last_30min: 47437.762789β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate lifetime: 54685.784343β
time=β2023-05-28 20:22:42β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate last_30min: 47714.465219β
time=β2023-05-28 20:22:42β level=warn pid=886 msg=βno ratio hashrate lifetime: 54752.431833β
time=β2023-05-28 20:22:43β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate last_30min: 47610.656195β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate lifetime: 54826.859758β
time=β2023-05-28 20:22:43β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate last_30min: 47437.762789β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate lifetime: 54685.784343β
time=β2023-05-28 20:22:43β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate last_30min: 47714.465219β
time=β2023-05-28 20:22:43β level=warn pid=886 msg=βno ratio hashrate lifetime: 54752.431833β
time=β2023-05-28 20:24:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:24:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:24:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:26:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:26:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:26:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:28:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:28:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:28:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:30:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:30:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:30:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:32:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:32:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:32:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:34:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:34:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:34:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:36:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:36:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:36:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:37:45β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate last_30min: 19435.704287β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 51155.556106β
time=β2023-05-28 20:37:45β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate last_30min: 19487.596216β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 51023.871738β
time=β2023-05-28 20:37:45β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate last_30min: 19515.079393β
time=β2023-05-28 20:37:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 51086.077460β
time=β2023-05-28 20:37:46β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate last_30min: 19435.704287β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 51155.556106β
time=β2023-05-28 20:37:46β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate last_30min: 19487.596216β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 51023.871738β
time=β2023-05-28 20:37:46β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate last_30min: 19515.079393β
time=β2023-05-28 20:37:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 51086.077460β
time=β2023-05-28 20:37:47β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate last_30min: 19435.704287β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 51155.556106β
time=β2023-05-28 20:37:47β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate last_30min: 19487.596216β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 51023.871738β
time=β2023-05-28 20:37:47β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate last_30min: 19515.079393β
time=β2023-05-28 20:37:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 51086.077460β
time=β2023-05-28 20:37:48β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate last_30min: 19435.704287β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 51155.556106β
time=β2023-05-28 20:37:48β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate last_30min: 19487.596216β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 51023.871738β
time=β2023-05-28 20:37:48β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate last_30min: 19515.079393β
time=β2023-05-28 20:37:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 51086.077460β
time=β2023-05-28 20:37:49β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate last_30min: 19435.704287β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 51155.556106β
time=β2023-05-28 20:37:49β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate last_30min: 19487.596216β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 51023.871738β
time=β2023-05-28 20:37:49β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate last_30min: 19515.079393β
time=β2023-05-28 20:37:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 51086.077460β
time=β2023-05-28 20:38:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:38:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:38:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:38:23β level=warn pid=886 poolno=0 msg=βnot responding!β
time=β2023-05-28 20:40:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:40:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:40:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:40:23β level=warn pid=886 poolno=1 pool=stratum+tcp://kda.f2pool.com:5400 msg=βstable for >120 secondsβ
time=β2023-05-28 20:42:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:42:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:42:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:44:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:44:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:44:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:46:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:46:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:46:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:48:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:48:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:48:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:50:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:50:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:50:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:52:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:52:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:52:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:52:44β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:44β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:52:44β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 20:52:44β level=warn pid=886 msg=βno ratio hashrate lifetime: 47961.643942β
time=β2023-05-28 20:52:44β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:44β level=warn pid=886 msg=βno ratio hashrate lifetime: 47838.213964β
time=β2023-05-28 20:52:44β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:44β level=warn pid=886 msg=βno ratio hashrate lifetime: 47896.518984β
time=β2023-05-28 20:52:45β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:45β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:52:45β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 20:52:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 47961.643942β
time=β2023-05-28 20:52:45β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 47838.213964β
time=β2023-05-28 20:52:45β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 47896.518984β
time=β2023-05-28 20:52:46β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:46β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:52:46β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 20:52:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 47961.643942β
time=β2023-05-28 20:52:46β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 47838.213964β
time=β2023-05-28 20:52:46β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 47896.518984β
time=β2023-05-28 20:52:47β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:47β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:52:47β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 20:52:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 47961.643942β
time=β2023-05-28 20:52:47β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 47838.213964β
time=β2023-05-28 20:52:47β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 47896.518984β
time=β2023-05-28 20:52:48β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:48β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 20:52:48β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 20:52:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 47961.643942β
time=β2023-05-28 20:52:48β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 47838.213964β
time=β2023-05-28 20:52:48β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 20:52:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 47896.518984β
time=β2023-05-28 20:54:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:54:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:54:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:56:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:56:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:56:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 20:58:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 20:58:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 20:58:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:00:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:00:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:00:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:02:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:02:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:02:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:04:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:04:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:04:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:06:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:06:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:06:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:07:44β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:44β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:07:44β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:07:44β level=warn pid=886 msg=βno ratio hashrate lifetime: 45143.163929β
time=β2023-05-28 21:07:44β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:44β level=warn pid=886 msg=βno ratio hashrate lifetime: 45026.964931β
time=β2023-05-28 21:07:44β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:44β level=warn pid=886 msg=βno ratio hashrate lifetime: 45081.805455β
time=β2023-05-28 21:07:45β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:45β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:07:45β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:07:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 45143.163929β
time=β2023-05-28 21:07:45β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 45026.964931β
time=β2023-05-28 21:07:45β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:45β level=warn pid=886 msg=βno ratio hashrate lifetime: 45081.805455β
time=β2023-05-28 21:07:46β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:46β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:07:46β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:07:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 45143.163929β
time=β2023-05-28 21:07:46β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 45026.964931β
time=β2023-05-28 21:07:46β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:46β level=warn pid=886 msg=βno ratio hashrate lifetime: 45081.805455β
time=β2023-05-28 21:07:47β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:47β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:07:47β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:07:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 45143.163929β
time=β2023-05-28 21:07:47β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 45026.964931β
time=β2023-05-28 21:07:47β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:47β level=warn pid=886 msg=βno ratio hashrate lifetime: 45081.805455β
time=β2023-05-28 21:07:48β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:48β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:07:48β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:07:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 45143.163929β
time=β2023-05-28 21:07:48β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 45026.964931β
time=β2023-05-28 21:07:48β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:07:48β level=warn pid=886 msg=βno ratio hashrate lifetime: 45081.805455β
time=β2023-05-28 21:08:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:08:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:08:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:10:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:10:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:10:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:12:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:12:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:12:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:14:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:14:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:14:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:16:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:16:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:16:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:18:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:18:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:18:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:20:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:20:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:20:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:20:49β level=warn pid=886 poolno=0 msg=βnot responding!β
time=β2023-05-28 21:22:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:22:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:22:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:22:49β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:49β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:22:49β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:22:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 42624.387908β
time=β2023-05-28 21:22:49β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 42514.694275β
time=β2023-05-28 21:22:49β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 42566.447792β
time=β2023-05-28 21:22:50β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:50β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:22:50β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:22:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 42624.387908β
time=β2023-05-28 21:22:50β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 42514.694275β
time=β2023-05-28 21:22:50β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 42566.447792β
time=β2023-05-28 21:22:51β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:51β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:22:51β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:22:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 42624.387908β
time=β2023-05-28 21:22:51β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 42514.694275β
time=β2023-05-28 21:22:51β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 42566.447792β
time=β2023-05-28 21:22:52β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:52β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:22:52β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:22:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 42624.387908β
time=β2023-05-28 21:22:52β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 42514.694275β
time=β2023-05-28 21:22:52β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 42566.447792β
time=β2023-05-28 21:22:53β level=warn pid=886 poolno=0 pool=stratum+tcp://kda-us.ss.dxpool.com:6611 msg=βstable for >120 secondsβ
time=β2023-05-28 21:22:53β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:53β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:22:53β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:22:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 42624.387908β
time=β2023-05-28 21:22:53β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 42514.694275β
time=β2023-05-28 21:22:53β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:22:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 42566.447792β
time=β2023-05-28 21:24:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:24:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:24:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:26:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:26:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:26:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:28:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:28:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:28:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:30:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:30:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:30:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:32:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:32:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:32:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:34:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:34:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:34:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:36:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:36:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:36:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:37:49β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:49β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:37:49β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:37:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 40383.622939β
time=β2023-05-28 21:37:49β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 40279.717446β
time=β2023-05-28 21:37:49β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 40328.711111β
time=β2023-05-28 21:37:50β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:50β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:37:50β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:37:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 40383.622939β
time=β2023-05-28 21:37:50β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 40279.717446β
time=β2023-05-28 21:37:50β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 40328.711111β
time=β2023-05-28 21:37:51β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:51β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:37:51β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:37:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 40383.622939β
time=β2023-05-28 21:37:51β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 40279.717446β
time=β2023-05-28 21:37:51β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 40328.711111β
time=β2023-05-28 21:37:52β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:52β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:37:52β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:37:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 40383.622939β
time=β2023-05-28 21:37:52β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 40279.717446β
time=β2023-05-28 21:37:52β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 40328.711111β
time=β2023-05-28 21:37:53β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:53β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:37:53β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:37:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 40383.622939β
time=β2023-05-28 21:37:53β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 40279.717446β
time=β2023-05-28 21:37:53β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:37:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 40328.711111β
time=β2023-05-28 21:38:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:38:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:38:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:40:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:40:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:40:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:42:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:42:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:42:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:44:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:44:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:44:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:46:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:46:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:46:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:48:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:48:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:48:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:50:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:50:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:50:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:52:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:52:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:52:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:52:49β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:49β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:52:49β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:52:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 38366.666031β
time=β2023-05-28 21:52:49β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 38268.024390β
time=β2023-05-28 21:52:49β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:49β level=warn pid=886 msg=βno ratio hashrate lifetime: 38314.472112β
time=β2023-05-28 21:52:50β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:50β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:52:50β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:52:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 38366.666031β
time=β2023-05-28 21:52:50β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 38268.024390β
time=β2023-05-28 21:52:50β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:50β level=warn pid=886 msg=βno ratio hashrate lifetime: 38314.472112β
time=β2023-05-28 21:52:51β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:51β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:52:51β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:52:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 38366.666031β
time=β2023-05-28 21:52:51β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 38268.024390β
time=β2023-05-28 21:52:51β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:51β level=warn pid=886 msg=βno ratio hashrate lifetime: 38314.472112β
time=β2023-05-28 21:52:52β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:52β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:52:52β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:52:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 38366.666031β
time=β2023-05-28 21:52:52β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 38268.024390β
time=β2023-05-28 21:52:52β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:52β level=warn pid=886 msg=βno ratio hashrate lifetime: 38314.472112β
time=β2023-05-28 21:52:53β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:53β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 21:52:53β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 21:52:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 38366.666031β
time=β2023-05-28 21:52:53β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 38268.024390β
time=β2023-05-28 21:52:53β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 21:52:53β level=warn pid=886 msg=βno ratio hashrate lifetime: 38314.472112β
time=β2023-05-28 21:54:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:54:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:54:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:56:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:56:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:56:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 21:58:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 21:58:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 21:58:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:00:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:00:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:00:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:01:36β level=warn pid=886 poolno=0 msg=βnot responding!β
time=β2023-05-28 22:02:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:02:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:02:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:03:53β level=warn pid=886 poolno=0 pool=stratum+tcp://kda-us.ss.dxpool.com:6611 msg=βstable for >120 secondsβ
time=β2023-05-28 22:04:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:04:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:04:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:06:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:06:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:06:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:07:54β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:54β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:07:54β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:07:54β level=warn pid=886 msg=βno ratio hashrate lifetime: 36531.926467β
time=β2023-05-28 22:07:54β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:54β level=warn pid=886 msg=βno ratio hashrate lifetime: 36438.032777β
time=β2023-05-28 22:07:54β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:54β level=warn pid=886 msg=βno ratio hashrate lifetime: 36482.232353β
time=β2023-05-28 22:07:55β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:55β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:07:55β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:07:55β level=warn pid=886 msg=βno ratio hashrate lifetime: 36531.926467β
time=β2023-05-28 22:07:55β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:55β level=warn pid=886 msg=βno ratio hashrate lifetime: 36438.032777β
time=β2023-05-28 22:07:55β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:55β level=warn pid=886 msg=βno ratio hashrate lifetime: 36482.232353β
time=β2023-05-28 22:07:56β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:56β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:07:56β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:07:56β level=warn pid=886 msg=βno ratio hashrate lifetime: 36531.926467β
time=β2023-05-28 22:07:56β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:56β level=warn pid=886 msg=βno ratio hashrate lifetime: 36438.032777β
time=β2023-05-28 22:07:56β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:56β level=warn pid=886 msg=βno ratio hashrate lifetime: 36482.232353β
time=β2023-05-28 22:07:57β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:57β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:07:57β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:07:57β level=warn pid=886 msg=βno ratio hashrate lifetime: 36531.926467β
time=β2023-05-28 22:07:57β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:57β level=warn pid=886 msg=βno ratio hashrate lifetime: 36438.032777β
time=β2023-05-28 22:07:57β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:57β level=warn pid=886 msg=βno ratio hashrate lifetime: 36482.232353β
time=β2023-05-28 22:07:58β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:58β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:07:58β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:07:58β level=warn pid=886 msg=βno ratio hashrate lifetime: 36531.926467β
time=β2023-05-28 22:07:58β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:58β level=warn pid=886 msg=βno ratio hashrate lifetime: 36438.032777β
time=β2023-05-28 22:07:58β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:07:58β level=warn pid=886 msg=βno ratio hashrate lifetime: 36482.232353β
time=β2023-05-28 22:08:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:08:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:08:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:10:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:10:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:10:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:12:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:12:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:12:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:14:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:14:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:14:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:16:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:16:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:16:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:18:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:18:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:18:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:20:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:20:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:20:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:22:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:22:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:22:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:22:54β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:54β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:22:54β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:22:54β level=warn pid=886 msg=βno ratio hashrate lifetime: 34873.479791β
time=β2023-05-28 22:22:54β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:54β level=warn pid=886 msg=βno ratio hashrate lifetime: 34783.830737β
time=β2023-05-28 22:22:54β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:54β level=warn pid=886 msg=βno ratio hashrate lifetime: 34825.996075β
time=β2023-05-28 22:22:55β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:55β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:22:55β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:22:55β level=warn pid=886 msg=βno ratio hashrate lifetime: 34873.479791β
time=β2023-05-28 22:22:55β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:55β level=warn pid=886 msg=βno ratio hashrate lifetime: 34783.830737β
time=β2023-05-28 22:22:55β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:55β level=warn pid=886 msg=βno ratio hashrate lifetime: 34825.996075β
time=β2023-05-28 22:22:56β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:56β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:22:56β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:22:56β level=warn pid=886 msg=βno ratio hashrate lifetime: 34873.479791β
time=β2023-05-28 22:22:56β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:56β level=warn pid=886 msg=βno ratio hashrate lifetime: 34783.830737β
time=β2023-05-28 22:22:56β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:56β level=warn pid=886 msg=βno ratio hashrate lifetime: 34825.996075β
time=β2023-05-28 22:22:57β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:57β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:22:57β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:22:57β level=warn pid=886 msg=βno ratio hashrate lifetime: 34873.479791β
time=β2023-05-28 22:22:57β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:57β level=warn pid=886 msg=βno ratio hashrate lifetime: 34783.830737β
time=β2023-05-28 22:22:57β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:57β level=warn pid=886 msg=βno ratio hashrate lifetime: 34825.996075β
time=β2023-05-28 22:22:58β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:58β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:22:58β level=warn pid=886 msg=βno ratio hashrate last_30min: 0.000000β
time=β2023-05-28 22:22:58β level=warn pid=886 msg=βno ratio hashrate lifetime: 34873.479791β
time=β2023-05-28 22:22:58β level=warn pid=886 chain=1 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:58β level=warn pid=886 msg=βno ratio hashrate lifetime: 34783.830737β
time=β2023-05-28 22:22:58β level=warn pid=886 chain=2 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:22:58β level=warn pid=886 msg=βno ratio hashrate lifetime: 34825.996075β
time=β2023-05-28 22:24:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:24:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:24:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:26:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:26:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:26:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:28:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:28:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:28:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:30:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:30:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:30:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:32:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:32:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:32:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:34:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:34:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:34:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:36:19β level=error pid=886 msg=βSweep error string = J0:1.β
time=β2023-05-28 22:36:19β level=error pid=886 msg=βSweep error string = J1:1.β
time=β2023-05-28 22:36:19β level=error pid=886 msg=βSweep error string = J2:1.β
time=β2023-05-28 22:37:59β level=warn pid=886 chain=0 msg=βcheck_low_hashrate low hashrate happened!β
time=β2023-05-28 22:37:59β level=warn pid=886 msg=βno ratio hashrate last_5s: 0.000000β
time=β2023-05-28 22:37:59β level=warn pid=886 msg="no ratio hashrate last_30min: 0.000
