Help picking a mining pool
What is the most profitable way to mine etherum , most profitable pool and miner , I’ve been using phenix miner and ethermine.org pool but it doesn’t seem as profitable as nicehash with phenix miner ! I have 4 580s and 1 3090
You can see here the pools with there hashrate
ethermine is the 2nd largest pool, you should have significant earnings
NiceHash is most profitable at the moment
Or else try solo
Do your research. In my experience it doesn’t really matter what pool you use. Smaller pools will mean your rewards take more time to receive but are going to be bigger since there are less miners. Big pools will net you rewards more frequently but they are smaller. Also pay attention to what payout type the pool uses. I like PPS+.
