Can I set up a goldshell mini doge miner with just an iPad and cell phone?
Yes you can. If you have the non Wi-Fi mini Doge you will need to find the IP address assigned to the miner. There are apps that can scan your network for devices if you can’t figure your router out. If you have the Wi-Fi version please read the following doc from Goldshell.
Thank you so much. I finally received my power cord and was able to set it up using this method
