Not paying electric is a huge bonus for you.
Personally, I designed and printed 3D Printed ducting that attaches to the miner fans and enables you to connect a 5/6/7/8" ducting to the miner, then you have a vent in your window. This way the heat is blown out the window away from your miner. The cooler you can keep the room the Safer it is, but it’s also beneficial to the equipment as well.
With mining you will also need to understand and choice a mining pool to use. Then you will need to choose if you want to mine Solo or in a pool. I used https://www.viabtc.com they cover most of the coins out there and pay is fair. Website is easy to use and well presented. you will also need to decide how you’re going to exchange your mined coins for cash. Personally, I use https://ftx.com if you store coins there, they will also pay you interest on them! They have a debit card that’s linked to your account for easy access and the fees aren’t that bad considering how much and how long it normally takes. Mining pool V Solo – when you mine with a pool any coins mined are shared with the pool. But you can get paid daily if needed. Mining Solo mean you would only ever get anything when you mine a coin. Which the difficulty changes all the time and there is no guarantee you would ever get paid anything. Of course, you could be very lucky and mine coins all the time, there is nothing you can do to increase your chance other than increasing mining output.
You will also need to decide where you are going to store your mining income. Be it a software wallet or a hardware wallet. With a hardware wallet I would only recommend buying from the manufacture direct. no middlemen like eBay or amazon. https://trezor.io/ is who I use but again there are others out there. But consider how much money you are going to be storing and what you’re willing to spend to protect it. By far a hardware wallet is the safest! Weakest link is always the operator.
This again is something you will have to make a decision on.
My eBay store
Email [email protected]
I am located in Killeen Texas
I take Paypal, crypto, credit/debit card
