Hi, Looking for a profitable cheapish <£500 ish Miner with low power consumption?
I was wondering what people may Recommend? Many thanks
Try goldshell boxes or jasminer x4, with little nore than your budget you might get KS0 miner perhaps
Old post, but you could try a CPU mining rig. Crazy low power and lots of $ to be made.
Hi, can you explain a little bit more about this?
What kind of CPU/motherboard combos did you have in mind for the low budget CPU mining rig and are you talking about mining Zephyr or something else? Thanks!
Yeah, zephyr. You can pick up a full CPU mining rig for about $200 if you budget very carefully. Used parts, and something like a ryzen 5 3600 will get you started. As long as the motherboard is decent, you have an upgrade path all the way up to a ryzen 9 5900X or something like that.
