How do I send coins from Pancake swap
I just made my first swap on pancake but how do i pull the coins to my wallet. I traded bnb for safemoon and i don’t know how to pull them to a wallet they are sitting on pancake. Clearly i did something wrong.
I’m assuming you used metamask, if you did, Connect to pancake swap w/Metamask. Go in MetaMask, Click on ‘Assets’, scroll down and add a new token. Click on ‘Custom Tokens’ tab, and add in this address: 0x8076c74c5e3f5852037f31ff0093eeb8c8add8d3 (you can verify on https://bscscan.com/token/0x8076c74c5e3f5852037f31ff0093eeb8c8add8d3). The rest of the info should populate, and accept. You should then see the Safemoon tokens you traded in your wallet now.
Hope this helps!
