How can you determine which gpu it is on your mining rig if you have 6 gpu’s that ae the same. Using nicehash, gpuz or hwi.
Which is GPU for what? Not quite understanding the question
nicehash shows one of the gpu’s is running hot. How to do determine which gpu on the mining rig it is?
Install MSI Afterburner to help monitor each GPU. You could always disconnect each GPU one at a time until you don’t see an overheating unit. Nicehash is cool but I prefer other mining software
If you’re open to switching software hive os makes it easier to tell that kind of stuff. If not definitely msi after burner as mentioned above. Easy fan controls, temp displays, over clocking, just gives you actual control of each gpu
Thanks for updates. I wish each gpu had a serial number that would would display in nicehash or hwi so you would know which gpu it is on your mining rig
