How to fix a "temp lost" error on L7
This L7 give this error in the logs:
time="2025-08-05 12:10:39" level=error pid=917 chain=0 error="temp lost" msg=check_temp
time="2025-08-05 12:10:40" level=error pid=917 chain=0 error="temp lost" msg=check_temp
time="2025-08-05 12:10:40" level=fatal pid=917 chain=1 msg="read temp error! pcb temp count 2 chip temp count 2 uneffective value count 0"
time="2025-08-05 12:10:41" level=error pid=917 chain=0 error="temp lost" msg=check_temp
time="2025-08-05 12:10:41" level=error pid=917 chain=1 error="temp lost" msg=check_temp
time="2025-08-05 12:10:42" level=error pid=917 chain=0 error="temp lost" msg=check_temp
It does it after an hour or so, and need to be restarted to clear it. It doesn’t happen if the ambient air temp is kept very cool (18°C), but that may eat the margin that it makes unless it’s winter.
I’m guessing that this is a bad sensor because the other L7s that I have are in the same temperatures, and work fine.
Any ideas?
Flash firmware to Vnish and see what happens
