So after all the help, I have my 4x 1660 Super mining rig up and running. However, I was going through the BIOs settings and I could not find anywhere to set the system fan speeds. Ideally, I want these to just run at 100% to keep the rig as cool as possible. The only option I see is for CPU fan speed.
Is anyone familiar with the Biostar BIOs that can walk me through getting this set up?
A software option you could try is Speedfan if you are running Windows. I have never tried it since I hook them up directly to the PSU. http://www.almico.com/speedfan.php
I tried following a couple of tutorials on Speedfan, but I don’t have the options they list. I didn’t think about connecting to the PSU. I will do that.
