How to split mining profits
Those of you that have partners in your mining operations, how do you split the profits? Is it possible to mine equal shares into more than one wallet?
Thanks
Ok, I think I know the answer to that question now and what to do about it.
Here is another question. I just set up my first asic, a ck box and a neuron wallet to go with it. My question is about the neuron wallet itself. It seems that there no way to access multiple wallets from the same pc. Is that correct? Each person with a neuron wallet needs to have their own pc?
Thanks
