How to transfer HNS and CKB from dxpool to coinbase or mdax wallet?
Hello,
I am new to minning and I would really appreciate your advice!
How to transfer CKB and HNS from dxpool yo my wallet?
You needed to create a wallet before you started mining.
Ckb native wallet is Nervos. It’s very easy to setup and use.
Not sure about hns though.
I’ve heard Bob Wallet is the only HNS wallet at the moment but check to be sure. I also need to set up a HNS wallet soon.
This video & website seems to show how to set it up. I’ll try this next week.
Coinex will work for both HNS and CKB
