How to use box power supply (like Antec) w/ Doge Mini?
Hey everyone - I just started successfully mining ASICs (some low power, Doge minis). I’m looking to connect a few more, so I bought this Antec power supply (https://www.amazon.com/dp/B07XDHHTX8?th=1). I confirmed all specs, and the fact that the unit is working, but for some reason it’s not as simple as plug and play (when I plug in my Doge mini, it doesn’t turn on). Anyone have any tips? Like what am I missing? Really appreciate it!
You may need to jumpstart the power supply. Basically using a jumper between 2 pins on a connector since there is no motherboard to plug into. If you google or YouTube it you will see examples.
What Chsear11 said ^, you need to jump the sense pin for the power supply to engage. Its not meant for a miner its meant for a MB so it doesn’t see the signal, it doesn’t turn on. We just had another Doge miner with similar problem using a Dell server PS same issue.
Here’s how to jump start an atx power supply. Some power supplies come with a plug that is already jumpered.
https://www.goldshell.com/2020/09/01/instruction-of-atx-host-power/
