Update - See below for another way to see your NFT/Singleton Contract address
I see a number of users asking questions on how to use MadMax to create Chia plots, with the new NFT / Singleton that one creates to farm on a pool. I just wanted to share my findings, and I hope it helps you. Keep in mind the Cryptocurrency world is ever-changing, especially a newer project like Chia, so you may have to adapt and overcome. The basics should still help you, take care.
Update - You can find your contract address without the additional steps below, in the Windows wallet. Look for your NFT/Singleton name, and mouse over the question mark to right and copy **
Location of the folder, and Powershell commands:
Directory:
C:\Users*YourUSERNAME*\AppData\Local\chia-blockchain\app-YourAppNumber\resources\app.asar.unpacked\daemon\chia.exe plotnft show
Then it will ask you “Choose wallet key:” and you enter the number that corresponds to the correct wallet.
You’re looking for the address after the following words: “P2 singleton address (pool contract address for plotting):”
You will need to replace the -p command, with the new " -c " variable then enter in that contract address after it.
Previous video on how to connect to Space Pool: https://youtu.be/976i6557q7I
Official Pool.Space website: https://mainnet.pool.space/
MadMax Plotter download for Windows: https://github.com/stotiks/chia-plott…
