Hub for multiple miners
What kind of hub are you using to connect multiple miners to your router? Did anyone tried Hive setup? I will have to connect 10 miners to a single router and I’m looking for the best way.
I use an Ethernet switch off the router to connect 12 miners. Haven’t run into any issues.
Like this switch or similar.
