Hydro Bitcoin Mining - Water-Cooled BTC Miners New Industry Standard? Liquid-cooling your Bitcoin miners now achievs a 9.5 j/Th efficiency, making the new immersion miners, and especially hydro Bitcoin ASICs the most efficient and profitable Bitcoin miners out there. Hydro mining is like water-cooling your gaming PC, but enabling the biggest Bitcoin and Dogecoin passive income ever! Buy the BEST mini Bitcoin miner here - NerdQaxe++ preorder, June batch – Power Mining
Buy the cheapest tiny Bitcoin miner here - Bitaxe Gamma – Power Mining
don’t forget code VOSKCOIN to save some coin!
Order Bitcoin miners with CMC - Coin Mining Central - UK Cryptocurrency Mining Hardware Supplier
Terrahosting will run your Bitcoin miners for you! Home - Terra Hosting
If you use Terra Hosting make sure to let them know you found out about them on VoskCoin!
Check Mining Profitability with MiningNow - Discover Asic Miner Profitability in Real-Time | Mining Now
Let’s break down the mining metrics of the new Bitmain Antminer S23 Hydro, why it’s better than the air cooled Bitmain Antminer S23, and the Bitmain Antminer S23 Immersion miners. We will also review how the Bitcoin mining industry is shifting to all hydro miners, basically liquid cooled but specifically hydro which is basically water cooled Bitcoin miners are yielding the most efficient and dense Bitcoin mining rigs and then beyond that companies like Bitdeer are turning their Bitcoin miners into hydro miners, and microbt whatsminers hydro bitcoin miners and even volcminer hydro dogecoin miners and elphapex doge ltc asic mining rigs! Are these the best new Bitcoin miners? But wait until you hear the delivery date.
00:00 Bitcoin mining is bigger than ever!
00:38 What is Bitcoin Hydro mining?
01:39 Get a gamma or Nerdaxe++?
02:25 All big miner manufactures are making hydro miners
03:37 Hydro miners and heat reusability
05:31 Bitcoin miners are developing fast!
07:45 Crazy density in these Bitcoin miners
09:38 Should you start hydro mining?
11:31 Not expanding my Altcoin miners
12:49 Single phase to Three phase converter?
15:06 Foghashing getting into the hydro mining game
17:11 is Tails a Hydro Doge?
