Hello guys-
My s19 hydro should arrive by the end of this week, and I’m preparing the setup-
But what coolant should I use for the cooler/miner?
Tia ![]()
Hello guys-
Tia ![]()
You have a 12kw radiator right? You should double check but I’m pretty sure you would just use water. I would contact who ever sold you your equipment and get them to confirm what is needed
Yes I have the 12 kw radiator, the company selling that said destilled water, but I really wanted something colorful:face_holding_back_tears:![]()
Really you’ll only see the water in the pump which is tiny I reckon it holds 300ml tops, you might be able to put a light in there that changes color if you really want?
As long as it doesnt get sucked down into the hose and get stuck in your miner
might want to find one thats bigger and also cant block water leaving the pump
