I want to start mining but still don’t know how or what route to take
I have $1,000 and I want to used them right
What’s your recommendation?
First thing I’d recommend would be learning more about the algorithm you want to mine. There are a few different options you have available at the moment. Maybe look into helium mining proof of coverage setup. If you want to stick with GPU mining, which is fine too, it will be tough with these prices right now. But you can slowly buy parts as they become available, instead of thinking you can get everything all at one time. That’s where I think ppl will easily run up the cost bc they want to get started as soon as possible. Start watching Vosk coin and BitsbeTrippin YouTube channels to learn more about it! Hope this helps
