I figured how to be Mining KAS with a Goldshell Mini Doge Box
Today I found out you can mine KAS using script, equihash, shea-256
I logged into my GS MD Box and changed the pool settings and now have it mining KAS
Use my Referral code to get some savings on fees
Code-a332-f8r3
Referral Code you can lower your mining fee to 0.75% , just add it after your worker name, separated by a # symbol:
KAS**:** Address**.** Worker**#** referral-code
(*) The referral code won’t change your worker’s name in your stats page.
Share your referral code to earn 0.25% of your referral’s mining rewards , passively!
I’m obviously doing something wrong.
It’s hard to tell from your partial pool settings how you did this.
Could you show it in Pool Config?
Did you use scrypt.unmineable.com:3333?
WAIT WHAT? so If I have an L7 I could get 8 smthn gigahash on kas??
It would mine Ltc+Doge, and then switch it to Kaspa.
