Hi guys!
I ordered this machine:
Canaan AvalonMiner 1126 Pro 68th/s
Maybe someone have some thoughts about it? Is it still good in 2021? Is it good choice? Maybe you would suggest something different? I want to mine Bitcoin.
Hi guys!
This is the first miner you purchased? Well if it is GOOD LUCK with it. I wish I new more about it but this will ping your conversation so someone else can answer it for you.
Its a 3400 watt miner that only pushes 68TH. Its an older miner, likely used. I’m sorry to say that it probably won’t be profitable to run when bitcoin eventually goes back into a bear market. If you wanted to mine bitcoin long term it would have been better to pay more for the S19 110TH same power draw. 63% more hashpower.
Hope it works out for you.
Don’t let that stop you, run it, get to know it, and in the mean time keep learning about this space. You’re first machine is just that, and when you ask theses guys/gals more questions you find that we ALL have first machines that are in the bottom of our closets, along with our sexuality LMAO…Push the boundaries!
