I need some help with calculating my electric costs
so where I’m at I get a 0.06 cent electric cost but I think there are a bunch of fees so I need some help figuring these out. Any advice?
It would depend on the provider, you’ll have to check the bill… Also, often with residential you’ll find the cost goes up after a certain KWH usage, which you’ll likely break over if you’re running miners.
Take the total you pay and divide that by the total kWh for the month to find your all in cost.
I would love to help, put the numbers you have to work with in a post and I along with the community will help you with it
I use this link above - and all my miners are connected to smart plugs with energy meters so I can remote power off and see how much they are using for the calculations at the link
I just installed 6kW of solar on the garage which gets me below 6 cents
Nice! i wish i could do that but… $$
