Hey I’m Timmy from Alabama can I mine with a Laptop ? I really have no clue where to start and don’t know much about computers
hey their their are plenty of ways to mine on a laptop but know that its not profitable , but if you want to know how to mine the easy way i recommend using Honey miner check this video
But if you want to know how to mine for real use xmrig its a bit complicated but you will get a hang of it you’ll be able to mine XMR which is a little bit profitable cpu coin.
i hope this help
I’m going to give it a try😬
